uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Reference for the uipathctl snapshot delete command, which deletes a specific or all snapshot backups in Automation Suite.
Delete the snapshot backup.
uipathctl snapshot delete (name | --all) [flags]
Options
-a, --all Delete all the snapshots
-f, --force Forcibly delete the snapshot without confirmation
-h, --help help for delete
