uipathctl reference guide
uipathctl manifest apply
Reference for the uipathctl manifest apply command, which loads a configuration and applies it to the cluster in Automation Suite.
Description​
Load the configuration found at PATH, and apply it to the cluster.
The command performs a diff between the current state of the cluster and the desired state, and applies the changes to the cluster.
When the --override flag is present, the list overrides the selection found in the input file. The flag is mutually exclusive with the --only flag. When the exclude_components key is present in the input file, the components found in the list are excluded from the installed components. This has the highest priority over all the other flags and it is not mutually exclusive with any of them.
uipathctl manifest apply PATH [flags]
Examples​
# Apply the configuration found in input.json, using the versions found in versions.json
uipathctl manifest apply input.json/cluster_config.json --versions versions.json
# Apply the configuration and specify the kubeconfig file to use
uipathctl manifest apply input.json/cluster_config.json --kubeconfig cluster.kubeconfig --versions versions.json
# Simulate the apply command and print on stdout the result of the operation
uipathctl manifest apply --dry-run input.json/cluster_config.json --versions versions.json
# Apply the configuration but skip the components installed directly by helm
uipathctl manifest apply --skip-helm input.json/cluster_config.json --versions versions.json
# Apply the configuration overriding the initial list of components
uipathctl manifest apply --override automation_hub,orchestrator --versions versions.json
Options​
      --continue-on-error   if true, continue applying the manifest even if an error occurs
      --dependencies-only   if true, only dependencies will be applied
      --dry-run             if true, just print the result of the command, without applying it
      --fail-on-version     if true, fail if the version of the component is not found in the versions file
  -h, --help                help for apply
      --no-wait             if true, return immediately after the ArgoCD applications are created
      --only strings        optional exclusive list of components to apply
      --override strings    optional list to override the components enabled in input.json/cluster_config.json file
      --skip-dependencies   if true, dependencies will be skipped
      --skip-helm           if true, skip components installed directly by helm
      --versions string     path to versions file
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
