uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Reference for the uipathctl cluster migration import command and its flags for importing cluster state in Automation Suite.
The command executes the migration from a source directory to a target cluster.
uipathctl cluster migration import [flags]
Examples
# Import the cluster state from local directory to cluster
Options
-h, --help help for import
