uipathctl reference guide
uipathctl snapshot
Reference for the uipathctl snapshot command, flags, and options for managing cluster snapshots in Automation Suite.
Description​
Manage snapshots.
uipathctl snapshot [flags]
Options​
  -h, --help   help for snapshot
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
