uipathctl reference guide
uipathctl config argocd ca-certificates get
Reference for the uipathctl config argocd ca-certificates get command for retrieving ArgoCD trusted CA certificates in Automation Suite.
Description​
Get the ArgoCD trusted CA certificates.
uipathctl config argocd ca-certificates get [flags]
Options​
  -h, --help   help for get
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
