uipathctl reference guide
uipathctl prereq create
Reference for the uipathctl prereq create command, which creates external prerequisites such as object storage buckets and SQL databases in Automation Suite.
Description​
Creates the external prerequisites. These are primarily object storage buckets and SQL databases. The SQL databases required for the installation are created on the SQL server if the sql.create_db key is set in the config file. The object storage buckets are created in the cloud provider if the object_storage.create_bucket key is set in the config file.
uipathctl prereq create PATH [flags]
Examples​
# Create all external prerequisites
uipathctl prereq create input.json/cluster_config.json --versions versions.json
Options​
  -h, --help                help for create
      --location location   Location where the prerequisites are executed. one of [local, cluster] (default cluster)
  -o, --output output       Output format. one of [json,yaml,text] (default text)
      --versions string     Path to the versions file
Options inherited from parent commands​
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Stay updated
