uipathctl reference guide
uipathctl snapshot restore
Reference for the uipathctl snapshot restore command, flags, and options for restoring the cluster from a snapshot in Automation Suite.
Description​
Restore the cluster from the snapshot.
uipathctl snapshot restore [flags]
Options​
  -h, --help   help for restore
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
