uipathctl Reference Guide
Last updated Nov 11, 2024
uipathctl config saml-certificates update
Update the future SAML certificate providing the pfx and key as arguments.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config saml-certificates update [flags]uipathctl config saml-certificates update [flags]
Examples
# Update the saml certificate with the provided pfx file path and password from the cluster
        uipathctl identity update-saml-certificate --cert server.pfx --password password
        # Update the saml certificate with the provided pfx file path and password from the cluster identified by the current context in the kubeconfig file
        uipathctl identity update-saml-certificate --cert server.pfx --password password --kubeconfig cluster.kubeconfig        # Update the saml certificate with the provided pfx file path and password from the cluster
Options
--cert string       path to certificate
  -h, --help              help for update
      --password string   password for pfx file      --cert string       path to certificate
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
