- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Get the content of the latest revision or of the revision with the specified version.
The output is in JSON format.
uipathctl manifest get-revision [flags]uipathctl manifest get-revision [flags]# Get the revision with the specified version number from the cluster
uipathctl manifest get-revision --version number
# Get the latest revision from the cluster
# Get the latest revision from the cluster identified by the current context in the kubeconfig file
uipathctl manifest get-revision input.json/cluster_config.json --kubeconfig cluster.kubeconfig # Get the revision with the specified version number from the cluster
uipathctl manifest get-revision input.json/cluster_config.json --kubeconfig cluster.kubeconfig-h, --help help for get-revision
--version int specify revision version -h, --help help for get-revision
--version int specify revision version--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
