- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Disable the periodical snapshot backup of the cluster.
uipathctl snapshot backup disable [flags]
-h, --help help for disable
-p, --prefix string This will prefix the names of all the snapshot backups with the given string.
(default "snapshot")
