uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Reference for the uipathctl snapshot restore logs command, which shows logs for a specific restore operation in Automation Suite.
Show the logs for the restore operation. NAME denotes the name of the restore you want to show the logs for.
uipathctl snapshot restore logs NAME [flags]
Options
-h, --help help for logs
