uipathctl reference guide
Last updated Feb 24, 2025
uipathctl health test
Execute health tests on the cluster using the Kubernetes API. This command performs tests that may temporarily mutate the cluster state.
uipathctl health test [flags]uipathctl health test [flags]
Examples
        # Run health tests on the cluster
Options
  -h, --help   help for test  -h, --help   help for test
--excluded strings    components to be excluded from execution, defaults to none
--included strings    components to be included in the execution, defaults to all
  -o, --output output       output format. one of [json,yaml,text,junit] (default text)
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
© 2005-2026 UiPath. All rights reserved.
