- Overview
- About uipathctl
- uipathctl reference documentation
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
uipathctl is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS and Automation Suite on Linux.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
Note, however, that not all commands referenced in this guide are suitable for both Automation Suite on EKS/AKS and Automation Suite on Linux. If certain commands are exclusive to one Automation Suite flavor, they should be marked accordingly.
It is important to be aware of the specific naming conventions we employ for the Automation Suite configuration file:
input.json- Automation Suite on EKS/AKScluster_config.json- Automation Suite on Linux
For more information, including a complete list of uipathctl operations, see the uipathctl reference documentation.
You can install uipathctl on the Linux, macOS, and Windows platforms.
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
