- Overview
- Pre-installation
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Load the configuration file found in the parameter, and lists the applications created based on it. The runtime configuration is used to determine which applications are required. The output is always in tabular format. By default, the list is sorted alphabetically.
uipathctl manifest list-applications PATH [flags]uipathctl manifest list-applications PATH [flags]
# List the applications which are installed based on the configuration found in input.json
uipathctl manifest list-applications input.json
# List the applications which are installed based on the configuration found in input.json.
# Sort them by the order in which they need to be installed based on dependencies between them.
uipathctl manifest list-applications input.json --sort-by topological
# List the applications without headers
uipathctl manifest list-applications input.json --no-headers
# Override the initial list of enabled components
uipathctl manifest list-applications input.json --override gatekeeper,redis
-h, --help help for list-applications
--is-required string to check whether the component needs to install
--no-headers if true, print the output without headers
--override strings optional list of components to override the components enabled in input.json file
--sort-by sortBy if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical) -h, --help help for list-applications
--sort-by sortBy if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
