Process Mining
Comparar
Introducción​
En el modo Comparar , puedes comparar dos conjuntos de rutas de tu proceso. Esto te permite visualizar, comparar y analizar el rendimiento de un proceso y sus variaciones en todos los paneles de tu aplicación de proceso.
Mostrar el panel Comparar por​
In the Compare by panel you can select which field you want to use for the comparison. Follow this step to display the Compare by panel.
  1. Haz clic en Imagen de documentos en la esquina superior derecha del panel.
The process app is displayed in Compare mode and the Compare by panel is displayed to the right. See the illustration below.
Nota:
The Compare button is a toggle button. When the Compare by panel is visible, click on the Compare button to hide the Compare by panel.
Nota:
In Compare mode, the period filter and the Root cause button are disabled.
Añadir un filtro Comparar por​
Sigue estos pasos para añadir un filtro Comparar por .
  1. Click on Add filter and select one or more fields for comparison from the drop-down list.
    The Compare by panel displays two scenarios: A and B. Scenario A is the main scenario and Scenario B is the comparing scenario. If you have selected a filter, scenario B will automatically be set as the inverse of scenario A. Each scenario has a different color. These colors correspond to the colors of the two scenarios in the dashboard.
  2. Si quieres comparar valores de campo específicos, selecciona los valores deseados para los filtros mostrados en el panel Comparar por .
Consulta la siguiente ilustración.
If you have already specified filters in the Filters panel, these filters will be displayed in the Compare by panel.
Eliminar Comparar por filtros​
Follow this step to remove any Compare by filters.
  1. Click on the Clear all button at the top of the Compare by panel.
Los filtros se borran y ambos escenarios se eliminan del panel Comparar por .
Comparando​
Both scenarios are displayed for the KPIs in the context bar according to the color legend in the Compare by panel, which enables you to analyze the differences between the two scenarios for the KPIs. The value for Scenario A is displayed on the left and the value for Scenario B is displayed on the right. See the illustration below.
For the larger KPI charts, for example on the Summary dashboards, both scenarios are displayed as trend lines according to the color legend in the Compare by panel, which enables you to analyze the differences between the two scenarios for the KPIs over time. See the illustration below.
Diagramas de barra​
En los gráficos de barras, ambos escenarios son visibles para cada barra. Puede pasar el ratón por encima de una barra para ver la información de contexto. Consulta la siguiente ilustración.
Gráficos de proceso​
Con el gráfico de procesos, es posible comparar dos procesos diferentes en función de diferentes campos o diferentes períodos de tiempo. Ambos escenarios se combinan en el gráfico del proceso. Consulta la siguiente ilustración.
Para la métrica seleccionada, ambos escenarios son visibles en los bordes. Al pasar el ratón sobre un borde, se muestra la información de contexto. Consulta la siguiente ilustración.
Diagramas de barra verticales​
En los gráficos de barras, ambos escenarios son visibles para cada barra. Consulta la siguiente ilustración.
Diagramas de una línea​
En los gráficos de líneas, cada escenario se muestra como una línea independiente. Consulta la siguiente ilustración.
