- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Disable the periodical snapshot backup of the cluster.
uipathctl snapshot backup disable [flags]uipathctl snapshot backup disable [flags] -h, --help help for disable
-p, --prefix string This will prefix the names of all the snapshot backups with the given string.
(default "snapshot") -h, --help help for disable
(default "snapshot") --context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
