uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Change the Orchestrator custom configuration.
uipathctl config orchestrator [flags]
Options
-h, --help help for orchestrator
