uipathctl Reference Guide
Last updated Nov 11, 2024
uipathctl snapshot restore history
Show the restore history.
uipathctl snapshot restore history [flags]uipathctl snapshot restore history [flags]
Options
-h, --help   help for history  -h, --help   help for history
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
