uipathctl reference guide
uipathctl snapshot restore logs
Description​
Show the logs for the restore operation. NAME denotes the name of the restore you want to show the logs for.
uipathctl snapshot restore logs NAME [flags]
Options​
  -h, --help   help for logs
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Stay updated
