OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl snapshot delete
Delete the snapshot backup.
uipathctl snapshot delete (name | --all) [flags]uipathctl snapshot delete (name | --all) [flags]
Options
  -a, --all     Delete all the snapshots
  -f, --force   Forcibly delete the snapshot without confirmation
  -h, --help    help for delete  -a, --all     Delete all the snapshots
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
