uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl identity enable-basic-auth
- Monitoring and alerting
- Troubleshooting
Generate configuration files for Dex connectors. For a complete list of valid connector types and more information about each field, see Dex documentation.
uipathctl sso generate-connector [flags]
Examples
Generate an empty configuration for an LDAP connector:
uipathctl sso generate-connector -t ldap
Options
-h, --help help for generate-connector
-t, --type connector-type the type of connector (default ldap)
