OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl identity enable-basic-auth
Enable basic authentication for the provided organization. The command defaults to the current context in thekubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
Examples
        # Enable basic auth for the provided organization in cluster
        uipathctl identity enable-basic-auth --orgname organization
        # Enable basic auth for the provided organization in the cluster identified by the current context in the kubeconfig file
        uipathctl identity enable-basic-auth --orgname organization --kubeconfig cluster.kubeconfig
Options
  -h, --help             help for enable-basic-auth
--orgname string   organization name  -h, --help             help for enable-basic-auth
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
