OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl cluster maintenance disable
Disable maintenance mode for the cluster.
uipathctl cluster maintenance disable [flags]uipathctl cluster maintenance disable [flags]
Options
  -h, --help   help for disable  -h, --help   help for disable
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
