OUT OF SUPPORT
uipathctl reference guide
uipathctl identity add-host-admin
Add or update a host admin with the provided credentials. The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl identity add-host-admin [flags]uipathctl identity add-host-admin [flags]
Examples
        # Add host admin with the provided username and password in cluster
        uipathctl identity add-host-admin --username newadmin --password password
        # Add host admin with the provided username, password and email in cluster
        uipathctl identity add-host-admin --username newadmin --email email --password password
        # Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
        uipathctl identity add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig
Options
  -e, --email string      host admin email
  -h, --help              help for add-host-admin
  -p, --password string   host admin password
  -u, --username string   host admin username  -e, --email string      host admin email
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
