uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Get the current SAML certificate used in the cluster in pem format.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl identity get-saml-certificate [flags]
Examples
# Get the current saml certificate from the cluster
# Get the current saml certificate from the cluster with additional certificate information
uipathctl identity get-saml-certificate --show-details
# Get the current saml certificate from the cluster identified by the current context in the kubeconfig file
uipathctl identity get-saml-certificate --kubeconfig cluster.kubeconfig
Options
-h, --help help for get-saml-certificate
--show-details if true, additional saml certificate information will be printed
