- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Get prints on stdout the current manifest observed in the cluster. The format is always
YAML.
The command will default to the current context in the
kubeconfig file. If the --kubeconfig flag is set, it will use the kubeconfig file specified by the flag. Without other flags, the cluster wide configurations and dependencies are not included in the
output.
uipathctl manifest get [flags]uipathctl manifest get [flags]
# Get the current manifest observed in the cluster, without dependencies or cluster wide configurations
# Get the current manifest from the cluster identified by the current context in the kubeconfig file
uipathctl manifest get --kubeconfig /root/kubeconfig
# Get the current manifest, including the cluster wide configurations and the dependencies
uipathctl manifest get --include-config --include-dependencies
-h, --help help for get
--ignore-errors ignore errors when getting the manifest
--include-config include cluster wide config in the diff
--include-dependencies include dependencies in the diff
-o, --output output output format. one of [json,yaml] (default yaml) -h, --help help for get
-o, --output output output format. one of [json,yaml] (default yaml) --context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
