OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl snapshot
Manage snapshots.
uipathctl snapshot [flags]uipathctl snapshot [flags]
Options
  -h, --help   help for snapshot  -h, --help   help for snapshot
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
