OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl snapshot backup enable
Enable the periodical snapshot backup of the cluster.
uipathctl snapshot backup enable [flags]uipathctl snapshot backup enable [flags]
Options
-h, --help               help for enable
  -p, --prefix string      This will prefix the names of all the snapshot backups with the given string.
                           	This is only used if you wish to enable schedule backup.
                             The default value is snapshot
                           	 (default "snapshot")
  -r, --retention string   Retention policy in duration format Hh:Mm:Ss, for e.g 8h5m1s.
                           	Default value of 168h.
                           	 (default "168h")
      --schedule string    Unix cron expression for schedule
                           	this is only required if you wish to enable schedule backup.
                             Default value "*/45 * * * *" denotes every 45th minutes backup is triggered.
                           	 (default "*/45 * * * *")  -h, --help               help for enable
                           	 (default "168h")
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
