OUT OF SUPPORT
uipathctl reference guide
uipathctl identity get-token-signing-certificate
Get the current token-signing certificate used in the cluster in pem format.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl identity get-token-signing-certificate [flags]uipathctl identity get-token-signing-certificate [flags]
Examples
        # Get the current token signing certificate from the cluster
        # Get the current token signing certificate from the cluster with additional certificate information
        uipathctl identity get-token-signing-certificate --show-details
        # Get the current token signing certificate from the cluster identified by the current context in the kubeconfig file
        uipathctl identity get-token-signing-certificate --kubeconfig cluster.kubeconfig
Options
  -h, --help           help for get-token-signing-certificate
--show-details   if true, additional token certificate information will be printed  -h, --help           help for get-token-signing-certificate
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
