OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl sso generate-overlays
Generate the Kustomize overlays for the SSO deployment of the fabric.
uipathctl sso generate-overlays [flags]uipathctl sso generate-overlays [flags]
Examples
Generate the overlays for a HA deployment of both ArgoCD and Dex, loading RBAC from a file
  uipathctl sso generate-overlays --argocd-base ha  --dex-base ha --argocd-url <https://argocd.local:30001> --rbac-file test-policies.csv --connector-file connector.yaml --dex-url <https://dex.local:32000> --kustomize-root ./hack/test/sso/kustomize
Options
--argocd-base string      ArgoCD kustomize base directory to use
--argocd-url string       The externally accessible URL for ArgoCD (must include port if not standard for protocol)
--connector-file string   Path to the Dex Connector's configuration file
--dex-base string         Dex base kustomization to use
--dex-url string          The externally accessible URL for Dex
--dex-use-https           Optionally use https for Dex
  -h, --help                    help for generate-overlays
--kustomize-root string   Kustomize root directory
--rbac-file string        Optional file to load the RBAC config for ArgoCD from (Overwrites policy.csv in the argocd-rbac-cm ConfigMap)--argocd-base string      ArgoCD kustomize base directory to use
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
