- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Get the current Orchestrator custom config in
pem format.
The command defaults to the current context in the
kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config orchestrator get-config [flags]uipathctl config orchestrator get-config [flags]# Get the current orchestrator custom config from the cluster
# Get the current orchestrator custom config from the cluster identified by the current context in the kubeconfig file
uipathctl config orchestrator get-config --kubeconfig cluster.kubeconfig
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
