uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl resource report
Generates a report on the resources in the cluster.
uipathctl resource report [flags]
Examples
# Generates a resource report
Options
-h, --help help for report
--output output The output of the report. Can be one of: json, minreqsgo (default json)
