- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Update the TLS certificates with the CA certificate and key provided as arguments.
If the provided key is encrypted, use the
--password flag specifying the decryption password. The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config tls-certificates update [flags]uipathctl config tls-certificates update [flags]
# Update the tls certificates with the provided certificate paths and key path from the cluster
uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.key
# Update the tls certificates with the provided certificate paths and encrypted key path from the cluster
uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.key --password password
# Update the tls certificates with the provided certificate paths and key path from the cluster identified by the current context in the kubeconfig file
uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.key --kubeconfig cluster.kubeconfig
--cacert string path to ca certificate
--cert string path to certificate
-h, --help help for update-tls-certificates
--key string path to certificate key
--password string password for encrypted key--cacert string path to ca certificate
--password string password for encrypted key--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
