OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl snapshot backup create
Back up the snapshot of the cluster. NAME denotes the name associated with the snapshot backup.
uipathctl snapshot backup create NAME [flags]uipathctl snapshot backup create NAME [flags]
Options
-h, --help   help for create
  -w, --wait   wait until the backup completes (default false)  -h, --help   help for create
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
