uipathctl reference guide
uipathctl prereq run
Description​
Runs the prerequisite checks to validate that the installation would succeed.
uipathctl prereq run PATH [flags]
Examples​
        # Runs all the prerequisite checks
        uipathctl prereq run input.json --versions versions.json
Options​
  -h, --help              help for run
--versions string   path to versions file
Options inherited from parent commands​
--excluded strings    components to be excluded from execution, defaults to none
--included strings    components to be included in the execution, defaults to all
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Stay updated
