uipathctl reference guide
uipathctl identity update-saml-certificate
Update the future SAML certificate with the pfx and key provided as arguments.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl identity update-saml-certificate [flags]uipathctl identity update-saml-certificate [flags]
Examples
        # Update the saml certificate with the provided pfx file path and password from the cluster
        uipathctl identity update-saml-certificate --cert server.pfx --password password
        # Update the saml certificate with the provided pfx file path and password from the cluster identified by the current context in the kubeconfig file
        uipathctl identity update-saml-certificate --cert server.pfx --password password --kubeconfig cluster.kubeconfig
Options
--cert string       path to certificate
  -h, --help              help for update-saml-certificate
--password string   password for pfx file--cert string       path to certificate
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
