OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl resource
Resource-related commands.
uipathctl resource [flags]uipathctl resource [flags]
Options
-h, --help help for resource-h, --help help for resource
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
