uipathctl reference guide
uipathctl config alerts
Description​
Configure alert of email type.
uipathctl config alerts [flags]
Options​
  -h, --help   help for alerts
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Stay updated
