- Overview
- Pre-installation
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl prereq
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl prereq
--excluded strings components to be excluded from execution, defaults to none
-h, --help help for prereq
--included strings components to be included in the execution, defaults to all
