- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Update the future token signing certificate with the certificate and key provided as arguments.
If the provided key is encrypted, set the
--password flag specifying the decryption password. The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl identity update-token-signing-certificate [flags]uipathctl identity update-token-signing-certificate [flags]
# Update the token signing certificate with the provided certificate path and key path from the cluster
uipathctl identity update-token-signing-certificate --cert server.crt --key server.key
# Update the token signing certificate with the provided certificate path and encrypted key path from the cluster
uipathctl identity update-token-signing-certificate --cert server.crt --key server.key --password password
# Update the token signing certificate with the provided certificate path and key path from the cluster identified by the current context in the kubeconfig file
uipathctl identity update-token-signing-certificate --cert server.crt --key server.key --kubeconfig cluster.kubeconfig
--cert string path to certificate
-h, --help help for update-token-signing-certificate
--key string path to certificate key
--password string password for encrypted key--cert string path to certificate
--password string password for encrypted key--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
