Linux 版 Automation Suite 安装指南
为 ArgoCD 启用 SSO
概述​
The uipathctl.sh script is required to enable SSO authentication. For more details on the script and the parameters you need to use, see Using uipathctl.sh.
准备配置文件​
在为 ArgoCD 启用 SSO 之前,您必须生成 RBAC 文件和连接器文件。
RBAC 文件​
RBAC 文件包含访问规则。
有关内置角色定义的详细信息,请参阅ArgoCD 文档。
For details on the ArgoCD account types and their permissions, see Managing the cluster in ArgoCD.
我们建议在定义组时使用这些角色,但您可以创建自己的权限集。
配置 RBAC 文件​
  1. 创建一个名为policy.csv的文件,添加以下内容,然后保存文件:
    p, role:uipath-sync, applications, get, */*, allow
    p, role:uipath-sync, applications, sync, */*, allow
    g, argocdro, role:uipath-sync
  2. 通过将以下行附加到policy.csv RBAC 文件,将 RBAC 组与内置管理员角色和 UiPath™ argocdro只读角色相关联:
    g, <your_ldap_readonly_group_name>, role:uipath-sync
    g, <your_ldap_admin_group_name>, role:admin
  3. 保存更新的policy.csv RBAC 文件。
示例:
假设 ArgoCD 管理员的 LDAP 组为“Administrators”,ArgoCD 只读用户的 LDAP 组为“Readers”,则 RBAC 文件应为:
g, Readers, role:uipath-sync
g, Administrators, role:admin
有关更高级的用例,请参阅默认的 RBAC 文件。
# Built-in policy which defines two roles: role:readonly and role:admin,
# and additionally assigns the admin user to the role:admin role.
# There are two policy formats:
# 1. Applications, logs, and exec (which belong to a project):
# p, <user/group>, <resource>, <action>, <project>/<object>
# 2. All other resources:
# p, <user/group>, <resource>, <action>, <object>
p, role:readonly, applications, get, */*, allow
p, role:readonly, certificates, get, *, allow
p, role:readonly, clusters, get, *, allow
p, role:readonly, repositories, get, *, allow
p, role:readonly, projects, get, *, allow
p, role:readonly, accounts, get, *, allow
p, role:readonly, gpgkeys, get, *, allow
p, role:readonly, logs, get, */*, allow
p, role:admin, applications, create, */*, allow
p, role:admin, applications, update, */*, allow
p, role:admin, applications, delete, */*, allow
p, role:admin, applications, sync, */*, allow
p, role:admin, applications, override, */*, allow
p, role:admin, applications, action/*, */*, allow
p, role:admin, applicationsets, get, */*, allow
p, role:admin, applicationsets, create, */*, allow
p, role:admin, applicationsets, update, */*, allow
p, role:admin, applicationsets, delete, */*, allow
p, role:admin, certificates, create, *, allow
p, role:admin, certificates, update, *, allow
p, role:admin, certificates, delete, *, allow
p, role:admin, clusters, create, *, allow
p, role:admin, clusters, update, *, allow
p, role:admin, clusters, delete, *, allow
p, role:admin, repositories, create, *, allow
p, role:admin, repositories, update, *, allow
p, role:admin, repositories, delete, *, allow
p, role:admin, projects, create, *, allow
p, role:admin, projects, update, *, allow
p, role:admin, projects, delete, *, allow
p, role:admin, accounts, update, *, allow
p, role:admin, gpgkeys, create, *, allow
p, role:admin, gpgkeys, delete, *, allow
p, role:admin, exec, create, */*, allow
g, role:admin, role:readonly
g, admin, role:admin
LDAP 连接器文件​
LDAP 连接器文件包含为 ArgoCD 配置 SSO 所需的 LDAP 参数。
备注:
If you already have an LDAP connector file (ldap_connector.yaml), skip to Enabling the SSO for ArgoCD.
要通过 LDAP 配置 SSO,请执行以下步骤:
  1. 通过运行以下命令生成 LDAP 模板文件。 将在运行命令的目录中生成连接器模板文件。
    ./uipathctl.sh sso-generate-connector --sso-connector-type ldap --install-type [online|offline] --accept-license-agreement
  2. 复制从---开始的输出,并将其另存为ldap_connector.yaml 。
    OpenLDAP 连接器文件示例:
    type: ldap
    # Required field for connector id.
    # Required field for connector name.
    config:
      host: openldap:389
      insecureNoSSL: true
      startTLS: false
      bindDN: cn=admin,dc=example,dc=org
      bindPW: adminpassword
      usernamePrompt: Email Address
      userSearch:
        baseDN: ou=People,dc=example,dc=org
        filter: "(objectClass=person)"
        username: mail
        idAttr: DN
        emailAttr: mail
        nameAttr: cn
      # Group search queries for groups given a user entry.
      groupSearch:
        baseDN: ou=Groups,dc=example,dc=org
        filter: "(objectClass=groupOfNames)"
        userMatchers:
          - userAttr: DN
            groupAttr: member
        nameAttr: cn
    type: ldap
    config:
      host: openldap:389
      insecureNoSSL: true
      startTLS: false
      userSearch:
        username: mail
        idAttr: DN
        emailAttr: mail
        nameAttr: cn
      groupSearch:
        userMatchers:
          - userAttr: DN
            groupAttr: member
        nameAttr: cn
    Active Directory LDAP 连接器文件示例:
    type: ldap
    config:
      bindDN: cn=admin,cn=Users,dc=example,dc=local
      bindPW: "<admins's password>"
      groupSearch:
        baseDN: dc=example,dc=local
        filter: "(objectClass=group)"
        nameAttr: cn
        userMatchers:
          - userAttr: distinguishedName
            groupAttr: member
      host: "ldaphost:389"
      insecureNoSSL: true
      insecureSkipVerify: true
      startTLS: false
      userSearch:
        baseDN: cn=Users,dc=example,dc=local
        emailAttr: userPrincipalName
        filter: (objectClass=person)
        idAttr: DN
        nameAttr: cn
        username: userPrincipalName
    type: ldap
    config:
      groupSearch:
        nameAttr: cn
        userMatchers:
            groupAttr: member
      insecureNoSSL: true
      startTLS: false
      userSearch:
        idAttr: DN
        nameAttr: cn
  3. 使用所需信息更新 LDAP 连接器文件并保存。 我们建议使用 LDAPS。
为 ArgoCD 启用 SSO​
准备 RBAC 和连接器文件后,您可以为 ArgoCD 启用 SSO。
使用 LDAP​
通过在存储连接器文件的目录中运行以下命令,为 ArgoCD 启用 SSO:
./uipathctl.sh sso-apply-overlays --install-type [online|offline] --accept-license-agreement --sso-connector-file ldap_connector.yaml --sso-rbac-file policy.csv
备注:
运行上一个命令后,您应该会在 ArgoCD 登录页面上看到一个 SSO 登录按钮。 提供公司域的用户名和密码。
  • 概述​
  • 准备配置文件​
  • RBAC 文件​
  • LDAP 连接器文件​
  • 为 ArgoCD 启用 SSO​
  • 使用 LDAP​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
