Linux 版 Automation Suite 安装指南
如何卸载集群
如果您遇到特定于集群上运行的 Kubernetes 的问题,可以直接卸载 rke2 集群。
  1. 根据您的安装配置文件,运行以下命令之一:
    1.1. 在在线设置中,在集群的每个节点上以提升的特权(即sudo )运行以下脚本。 这将卸载节点。
    function remove_rke2_entry_from_exclude() {
      local current_exclude_list new_exclude_list
      YUM_CONF_FILE=$1
      if [[ ! -s "${YUM_CONF_FILE}" ]];
      then
        # File is empty
        return
      fi
      current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1)
      if echo "$current_exclude_list" | grep -q 'rke2-*';
      then
        if [[ -w ${YUM_CONF_FILE} ]];
        then
          new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}")
          new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}")
          new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}")
          sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}"
          echo "${new_exclude_list}" >> "${YUM_CONF_FILE}"
        else
          error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work."
        fi
      fi
    function enable_rke2_package_upgrade() {
      remove_rke2_entry_from_exclude /etc/dnf/dnf.conf
      remove_rke2_entry_from_exclude /etc/yum.conf
    service_exists() {
        local n=$1
        if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then
            return 0
        else
            return 1
        fi
    if service_exists rke2-server; then
      systemctl stop rke2-server
      systemctl disable rke2-server
    fi
    if service_exists rke2-agent; then
      systemctl stop rke2-agent
      systemctl disable rke2-agent
    fi
    if [ -e /usr/bin/rke2-killall.sh ]
    then
        echo "Running rke2-killall.sh"
        /usr/bin/rke2-killall.sh > /dev/null
    else
        echo "File not found: rke2-killall.sh"
    fi
    if [ -e /usr/bin/rke2-uninstall.sh ]
    then
        echo "Running rke2-uninstall.sh"
        /usr/bin/rke2-uninstall.sh > /dev/null
    else
        echo "File not found: rke2-uninstall.sh"
    fi
    crontab -l > backupcron
    sed -i '/backupjob/d' backupcron > /dev/null
    crontab backupcron > /dev/null
    rm -rf backupcron > /dev/null
    rm -rfv /usr/bin/backupjob > /dev/null
    rm -rfv /etc/rancher/ > /dev/null
    rm -rfv /var/lib/rook/ > /dev/null
    rm -rfv /var/lib/longhorn/ > /dev/null
    rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null
    umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true
    rm -rfv /var/lib/rancher/* > /dev/null
    while ! rm -rfv /var/lib/kubelet/* > /dev/null; do
      findmnt --list   --submounts  -n -o TARGET  --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins'  | xargs -r umount -f -l
      sleep 5
    done
    umount -l -f /var/lib/kubelet
    rm -rfv /datadisk/* > /dev/null
    umount -l -f /datadisk
    rm -rfv ~/.uipath/* > /dev/null
    rm -rfv /etc/sysconfig/rke2-server > /dev/null
    rm -rfv /etc/sysconfig/rke2-agent > /dev/null
    mount /var/lib/rancher
    mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a
    echo "Uninstall RKE complete."
      YUM_CONF_FILE=$1
      then
        # File is empty
        return
      fi
      then
        then
        else
        fi
      fi
    service_exists() {
        local n=$1
            return 0
        else
            return 1
        fi
    fi
    fi
    then
    else
    fi
    then
    else
    fi
      sleep 5
    done
    1.2 在离线设置中,在集群的每个节点上以提升的特权(即sudo )运行以下脚本。 这将卸载节点。
      YUM_CONF_FILE=$1
      then
        # File is empty
        return
      fi
      then
        then
        else
        fi
      fi
    service_exists() {
        local n=$1
            return 0
        else
            return 1
        fi
    fi
    fi
    if [ -e /usr/local/bin/rke2-killall.sh ]
    then
      /usr/local/bin/rke2-killall.sh > /dev/null
    else
    fi
    if [ -e /usr/local/bin/rke2-uninstall.sh ]
    then
      /usr/local/bin/rke2-uninstall.sh > /dev/null
    else
    fi
      sleep 5
    done
      YUM_CONF_FILE=$1
      then
        # File is empty
        return
      fi
      then
        then
        else
        fi
      fi
    service_exists() {
        local n=$1
            return 0
        else
            return 1
        fi
    fi
    fi
    then
    else
    fi
    then
    else
    fi
      sleep 5
    done
  2. 对 OSD 磁盘运行以下清理流程:
    重要提示:
    对于 1.16 及更高版本的 Rook-Ceph 版本,更改了 OSD 清理程序。有关详细信息,请参阅Rook 官方文档。
    for osddisk in $(find /dev/uipath/ceph -maxdepth 1 -mindepth 1 -type l); do
      devName=$(basename "${osddisk}")
      devPath="/dev/${devName}"
      sgdisk --zap-all "${devPath}"
      dd if=/dev/zero of="${devPath}" bs=1M count=100 oflag=direct,dsync
      blkdiscard "${devPath}"
    done
    ls /dev/mapper/ceph-* | xargs -I% -- dmsetup remove %
    rm -rf /dev/ceph-*
    rm -rf /etc/udev/rules.d/99-ceph-raw-osd.rules
    done
    rm -rf /dev/ceph-*
    1. 卸载后重新启动节点。
    重要提示:
    从集群中卸载某个节点时,您必须运行以下命令: kubectl delete node <node_name> 。 这将从集群中删除节点。
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
