- リリース ノート
- はじめる前に
- アクセス権を管理する
- 基本情報
- Integrations
- プロセス アプリを使用する
- アプリを作成する
- データを読み込む
- データ変換中
- ダッシュボードをカスタマイズする
- プロセス アプリをパブリッシュする
- アプリ テンプレート
- Efficiency - Order process velocity
- 効率性 - サプライヤーのパフォーマンス
- コンプライアンス - 規定外購買 (Maverick buying)
- KPI
- Purchase to Pay - SAP input fields
- 通知
- その他のリソース
Process Mining
The Order process velocity dashboard enables you to analyze and monitor the speed and efficiency of purchase order execution across the end-to-end Purchase to Pay process.
グラフ | 説明 |
PR to GR milestones |
A bar chart that shows the time intervals and milestones from the creation of the Purchase requisition (PR) to the completion of a Goods receipt (GR). The PR to GR milestones chart allows you to track the flow, timing, and efficiency of the end to end process from purchase requisition to goods delivery. |
Revision PO items analysis | A bar chart that provides information on the number and of changes made to purchase order (PO) items within the end-to-end process. |
Revision events analysis |
A bar chart that provides information on the number, type, and distribution of revision (change) events that occurred across PO items in the end-to-end process. The Revision event analysis chart allows you to analyze process instability and rework trends that reduce speed and impact the number of first time right PO items. |
傾向 | The graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order creation date. |
