Last updated Dec 23, 2025
Configuring NLog
Adding NLog extensions
Orchestrator loads the following extensions by default, so you do not need to include them in the folder or the NLog configuration:
  • NLog.Targets.ElasticSearch
  • UiPath.Orchestrator.Logs.Elasticsearch
  • Microsoft.ApplicationInsights.NLogTarget
  • NLog.Extensions.AzureEventHub
Only Linux-compatible extensions can be used in this setup, so make sure that your chosen NLog extension abides by this rule.
To make the extension available for use, it must uploaded to the cluster storage. The uipathctl command line tool can do this via the uipathctl config orchestrator upload command:
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directoryuipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directory
If you use an external storage configuration at the cluster level, you must indicate this by including the --is-external-storage parameter.
Advanced NLog configuration
Creating the advanced NLog configuration
  1. Create the nlog.config.json file containing the standard sections: extensions, targets and rules.
    The extensions section is an array of items that specify the extension assemblies, via assemblyFile, and the path of the assembly.
    If custom NLog plugins were loaded (as described in the Adding NLog extensions section), they will be referenced in the extensions section.
  2. Configure the target and rule in the nlog.config.json file.
  3. Apply the nlog.config.json file using the uipathctl command line tool:
    uipathctl config orchestrator update-config --nlog-config nlog.custom.jsonuipathctl config orchestrator update-config --nlog-config nlog.custom.json
    Important: This action overwrites the existing custom NLog configuration. You can check what the existing configuration is by using this command:
    uipathctl config orchestrator get-config --nlog-configuipathctl config orchestrator get-config --nlog-config
    Example nlog.config.json file that writes logs to Azure Blob:
    {   "NLog": {
            "extensions": [
                { "assemblyFile": "NLog.Extensions.AzureBlobStorage.dll" }
            "targets": {
                "azureBlob": {
                    "type": "AzureBlobStorage",
                    "connectionString": "DefaultEndpointsProtocol=https;AccountName=test;AccountKey=key;EndpointSuffix=core.windows.net",
                    "container": "orchestratorlogs",
                    "blobName": "${date:format=yyyy-MM-dd hh.mm}",
                    "layout": {
                      "type": "JsonLayout",
                      "includeAllProperties": true,
                      "Attributes": [
                        {"name": "ts","layout": "${longdate}"},
                        {"name": "level","layout": "${level:upperCase=true}"},
                        {"name": "logger","layout": "${logger}"},
                        {"name": "message","layout": "${message}"},
                        {"name": "exception","layout": "${onexception:${ui-pretty-exception}}"}
            "rules": { "70_Final": { "writeTo": "stdout,azureBlob" } }
    }{   "NLog": {
            "extensions": [
            "targets": {
                "azureBlob": {
                    "layout": {
                      "Attributes": [
    Example nlog.config.json file that writes robot logs to Splunk:
        "Nlog": {
            "extensions": [
                { "assemblyFile": "NLog.Targets.Splunk.dll" },
                { "assembly": "UiPath.Orchestrator.Logs.DatabaseBulk.NLogTarget" }
            "targets": {
                "Splunk": {
                    "type": "BufferingWrapper",
                    "flushTimeout": 5000,
                    "target": {
                        "type": "SplunkHttpEventCollector",
                        "serverUrl": "http://splunk.example.com",
                        "token": "splunk-token",
                        "channel": "",
                        "source": "${logger}",
                        "sourceType": "_json",
                        "index": "uipath",
                        "retriesOnError": "0",
                        "batchSizeBytes": "0",
                        "batchSizeCount": "0",
                        "includeEventProperties": "true",
                        "includePositionalParameters": "true",
                        "includeMdlc": "true",
                        "maxConnectionsPerServer": "10",
                        "ignoreSslErrors": "false",
                        "useProxy": "false",
                        "proxyUrl": "",
                        "proxyUser": "",
                        "proxyPassword": ""
            "rules": {
                "20_Robot_Primary": { "writeTo": "Splunk,database,insightsRobotLogs" }
        "Nlog": {
            "extensions": [
            "targets": {
                "Splunk": {
                    "target": {
                        "channel": "",
                        "index": "uipath",
                        "proxyUrl": "",
                        "proxyUser": "",
                        "proxyPassword": ""
            "rules": {
Updating the advanced NLog configuration
The uipathctl commands needed for updating the NLog configuration are:
  • uipathctl config orchestrator get-config --nlog-config- This exports the current configuration in a key-value pair json file, ready for editing.
    You can read more about it .
  • uipathctl config orchestrator update-config --nlog-config nlog.config.json - This updates the configuration with your changes.
  1. Export the current custom NLog configuration to a json file using this command:
    uipathctl config orchestrator get-config --nlog-config > nlog.config.jsonuipathctl config orchestrator get-config --nlog-config > nlog.config.json
  2. Edit the exported nlog.config.json file as needed. You can add, remove, or change any of its settings.
    Note: You must export the file again every time you need to make a change, since the update overwrites all NLog settings.
  3. Update the NLog configuration using this command:
    orchestrator config updateduipathctl config orchestrator update-config --nlog-config nlog.config.json
  • Adding NLog extensions
  • Advanced NLog configuration
  • Creating the advanced NLog configuration
  • Updating the advanced NLog configuration
