- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Accessing the Models
- Enabling or disabling Extended Languages OCR
- Allocating GPU resources for Document Understanding modern projects
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Nov 6, 2025
Important: To use the Extended Languages OCR, you need to have a valid license configured. The license is a base64 string file provided
by UiPath® over email. To obtain the license, file a support ticket under .
Obtaining access to Extended Languages OCR involves acceptance of the following additional terms and conditions:
- Redistribution of the license by the user to other organizations is strictly prohibited. This license is specifically intended for the use of the Extended Languages OCR as part of UiPath Automation Suite, and solely by the entity to which it is provided.
Users are obligated to submit usage reports every quarter, with deadlines on March 31st, June 30th, Sept 30th, and Dec 31st each year. These reports can be produced by navigating to the
uipath-as-platformstorage container and compressing the folder pathaistorage/org-00000000-0000-0000-0000-000000000001/tenant-00000000-0000-0000-0000-000000000001into a zip file. This zip file is then sent to a UiPath email address that will be provided with the license file.If you are using in-cluster objectstore, refer to How to collect DU usage data with in-cluster objectstore (Ceph) to retrieve the usage reports.
Non-compliance with these conditions will result in the inability to renew Extended OCR licenses.
The license file expires after 12 months, so a license renewal is needed every 12 months. There is a one month grace period, after which the container will cease processing requests.
After receiving the license string, continue with the steps from this procedure.
You can access the Extended Languages OCR using the following endpoint:
{FQDN}/<organization_id>/<tenant_id>/du_/extended-ocr.
