Last updated May 20, 2026
Step 1: Saving the connection strings
Save the following information for further usage:
  • The connection string for the Orchestrator database in the standalone deployment;
    • The test-automation database connection string.
  • The connection string for the Insights database in the standalone deployment;
  • The connection string for the AutomationSuite_Platform database in the Automation Suite deployment. You can retrieve the connection string from the input.json file, under the platform parameter.
  • The following Test Manager information from the appsettings.production.json file located in the Test Manager installation directory:
    • The connection string for the Test Manager database in the standalone deployment.
      You can find the connection string in the following key: Database.ConnectionString.testmanagementhub.
    • The storage location information stored in the Storage.Location key.
    • The information stored in the Security.DataEncryptionKey key.
    Note:
    If the appsettings.production.json file is encrypted, you can use the Test Manager provisioning tool to decrypt it. For more information, visit Test Manager config file encryption.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
