- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Nov 13, 2025
If you encounter issues affecting Task Mining, see the following:
The Task Mining service may fail to initialize in Kerberos environments due to:- A missing
kerberos-discoverygroup-user-keytabsecret. - The
discoverygroupapp not being included in theenabledAppsparameter of theIntegratedAuthapp.
Solution
To address the issue, take the following steps:- Create the missing
kerberos-discoverygroup-user-keytabsecret. You can duplicate an existing keytab secret and name the new one askerberos-discoverygroup-user-keytab. - Add
discoverygroupto theenabledAppsparameter in theIntegratedAuthapp configuration.
