Patch artifact download links
Download links for artifacts required to apply patches to Automation Suite on EKS/AKS, including uipathctl for each patch version.
This page provides the download links for the artifacts required to apply a patch.
2024.10.4 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2024.10.4 patches.
2024.10.4+patch1​
uipathctl​
To download uipathctl for Automation Suite 2024.10.4+patch1, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4-patch1/uipathctl-2024.10.4-patch1-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4-patch1/uipathctl-2024.10.4-patch1-windows-amd64.tar.gz
  • macOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4-patch1/uipathctl-2024.10.4-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2024.10.4+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.4+patch1/as-cmk-2024.10.4+patch1.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2024.10.4+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.4+patch1/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2024.10.4+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4+patch1/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2024.10.4+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4+patch1/mirror-registry.sh
hydrate-registry.sh​
To download hydrate-registry.sh for Automation Suite 2024.10.4+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4+patch1/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2024.10.4+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.4+patch1/versions.json
2024.10.3 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2024.10.3 patches.
2024.10.3+patch2​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch2/as-cmk-2024.10.3+patch2.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch2/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch2/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch2/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch2/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3+patch2/versions.json
2024.10.3+patch1​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch1/as-cmk-2024.10.3+patch1.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3+patch1/versions.json
2024.10.2 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2024.10.2 patches.
2024.10.2+patch1​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.2+patch1/as-cmk-2024.10.2+patch1.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2+patch1/versions.json
2024.10.1 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2024.10.1 patches.
2024.10.1+patch1​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2024.10.1+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.1+patch1/as-cmk-2024.10.1+patch1.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2024.10.1+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.1+patch1/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2024.10.1+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1+patch1/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2024.10.1+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1+patch1/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.1+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1+patch1/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2024.10.1+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.1+patch1/versions.json
2024.10.0 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2024.10.0 patches.
2024.10.0+patch1​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2024.10.0+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.0+patch1/as-cmk-2024.10.0+patch1.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2024.10.0+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.0+patch1/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2024.10.0+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0+patch1/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2024.10.0+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0+patch1/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.0+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0+patch1/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2024.10.0+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.0+patch1/versions.json
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
