Automation Suite on EKS/AKS Installation Guide
Last updated Dec 18, 2024
Installation fails when Velero is enabled
The Automation Suite installation might fail when Velero is enabled.
Solution
To fix the issue, take the following steps:
  1. Make sure Helm 3.14 runs on the jumpbox or laptop used for installing Automation Suite.
  2. Extract the configuration values of the failed Helm chart, which in this case is Velero:
    helm -n velero get values velero > customvals.yamlhelm -n velero get values velero > customvals.yaml
  3. Add the missing image pull secret in the customvals.yaml file, under the .image.imagePullSecrets path:
    image:
      imagePullSecrets:
      - uipathpullsecretimage:
      imagePullSecrets:
      - uipathpullsecret
  4. If Velero has already been installed, uninstall it:
    helm uninstall -n velero velerohelm uninstall -n velero velero
  5. Create a new file called velerosecrets.txt. Populate it with your specific information, as shown in the following example:
    AZURE_CLIENT_SECRET=<secretforserviceprincipal>
    AZURE_CLIENT_ID=<clientidforserviceprincipal>
    AZURE_TENANT_ID=<tenantidforserviceprincipal>
    AZURE_SUBSCRIPTION_ID=<subscriptionidforserviceprincipal>
    AZURE_CLOUD_NAME=AzurePublicCloud
    AZURE_RESOURCE_GROUP=<infraresourcegroupoftheakscluster>AZURE_CLIENT_SECRET=<secretforserviceprincipal>
  6. Encode the velerosecrets.txt file:
    export b64velerodata=$(cat velerosecrets.txt | base64)export b64velerodata=$(cat velerosecrets.txt | base64)
  7. Create the velero-azure secret in the velero namespace. Include the following content:
    apiVersion: v1
    kind: Secret
    metadata:
      namespace: velero
    data:
      cloud: <put the $b64velerodata value here>apiVersion: v1
    kind: Secret
    metadata:
      namespace: velero
    data:
  8. Reinstall Velero:
    helm install velero -n velero <path to velero - 3.1.6 helm chart tgz> -f customvals.yamlhelm install velero -n velero <path to velero - 3.1.6 helm chart tgz> -f customvals.yaml
  • Description
  • Solution
