Disaster recovery: Active/Passive configurations
Configure Active/Passive disaster recovery clusters for Automation Suite on EKS, including supported products and installation steps.
Important:
Active/Passive mode is currently available only for EKS.
Note:
Some Automation Suite products are not supported in Disaster Recovery - Active/Passive. You can install these products while installing the primary cluster only. For details, refer to Disaster recovery - Active/Passive.
The disaster recovery configuration requires that you install the two Automation Suite clusters separately. To install both the primary and secondary clusters in an Active/Passive deployment, you must configure the following input.json parameters:
ParameterDescription
fqdnIt represents the FQDN that, at the time of installation, points to the load balancer of the primary cluster.
For details, refer to DNS routing logic.
cluster_fqdnIt represents the cluster-specific FQDN (DNS) that points to the load balancer of the cluster you set up using the input.json file.
multisite.enabledIt indicates that Automation Suite must be configured to work multi-site. It must be set to true.
multisite.primaryIt indicates that this cluster is a primary cluster and must be set to true. It defaults to false to denote the secondary cluster.
multisite.other_kube_configIt indicates the base64-encoded kubeconfig file of another cluster. While installing the primary Automation Suite cluster, this value is unavailable and can be left as is. However, you must provide the value when rebuilding the primary automation suite later during recovery.
multisite.typeIt specifies the deployment type. You must set it to active-passive.
Optional: Proxy configuration
If you choose to configure a proxy, in addition to the standard proxy configuration described in Configuring the proxy, make sure the no_proxy variable includes the following values:
  • <traffic-manager-fqdn> - same value as fqdn in the disaster recovery configuration
  • <primary-cluster-fqdn> - same value as cluster_fqdn set in the primary cluster
  • <secondary-cluster-fqdn> - same value as cluster_fqdn set in the secondary cluster
The following example shows a valid proxy configuration:
"proxy": {
  "enabled": true,
  "http_proxy": "http://20.110.210.6:3128",
  "https_proxy": "http://20.110.210.6:3128",
  "no_proxy": "<secondary-cluster-fqdn>,<primary-cluster-fqdn>,<traffic-manager-fqdn>"
"proxy": {
  "enabled": true,
Multi-site configuration
This page describes how to set up a multi-site configuration with a primary and secondary cluster. The primary cluster is active and the secondary cluster is passive.
  1. In the configuration for the primary cluster option, the enabled option must be set to true.
      "multisite": {
        "enabled": true,
        "primary": true,
        "type": "active-passive"
      "multisite": {
        "enabled": true,
        "primary": true,
  2. In the configuration for the secondary cluster, the primary option must be set to false:
      "multisite": {
        "enabled": true,
        "primary": false,
        "other_kube_config": "[base64 encoded kubeconfig]",
      "multisite": {
        "enabled": true,
        "primary": false,
    You must supply the primary kubeconfig in base64 encoded string.
  3. Services that are not compatible with being in a passive state must be disabled. For more details on services that do not support Active/Passive mode, refer to the Disaster recovery - Active/Passive page.
  4. Ensure the certificates are consistent across the primary and secondary cluster, as this is not automatically checked or enforced.
  • Optional: Proxy configuration
  • Multi-site configuration
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
